Hematology Analyzer
The ADVIA 70 Hematology System may be small in size, but it's big on performance, delivering a full CBC and 5-part differential. Designed for speed and accuracy, this compact benchtop analyzer combines cost-effectiveness with impressive productivity. It?s ideal for use as a back-up machine, or a primary system in clinical/satellite laboratories. Alternatively, the ADVIA 70 Hematology System is suitable either on its own or twinned with another system for low to medium workload routine laboratories.
- Compact benchtop solution that provides 70 CBC-Diff samples per hour optimizes result turnaround time.
- Combination of optical, laser multi-dimensional and enhanced impedance technologies ensures accuracy and allows user confidence in results.
- Manual open (180 uL) and sample saver mode included as standard provide safety and flexibility.
- Optional auto-sampler provides walkaway processing for up to 30 sample tubes, freeing staff for other tasks.
- Ease-of-use plus fully automated daily cleaning function minimizes training requirements and facilitates operation.
- Color bar-coded reagent system minimizes the risk of errors.
- 100,000-sample storage capacity including cytograms provides comprehensive data for patient monitoring.
- 36 quality control files (12 lot numbers, 3 levels each) with Bull’s moving average (XB) provide information which ensures compliance with industry standards and integrity of results.
- 8 customizable normal ranges and alert limits provide maximum flexibility for varying patient populations.
- On-board maintenance and reagent logs simplify compliance with accreditation procedures.
- Bi-directional interface maximizes workflow efficiency.
- Automated calibration simplifies training.
- Only uses 90 uL of sample in sample saver mode.
- Only minimal operator training is necessary
- Automatic system cleaning keeps you up and running
| Height | 13 in |
| Length | 19 in |
| Weight | 131 lbs |
| Width | 23 in |
- Power supply required, VAC 100-240, 50/60 Hz
- Dimensions (HXWXD) cm: 33,5 x 58,4 x 49
- Weight, kg: 59.4
- Diffusion of laser light, electrical impedance
- Histogram display :Printer and screen
