Cardiac Science - Quinton Q-Stress
by Cardiac Science
Treadmill
The Quinton Q-Stress is the hospital industry's gold standard. Our cardiac stress test with treadmill system is the winner of multiple awards (most recently Frost & Sullivan's Market Engineering Award). Quinton Q-Stress is now in its ninth generation. New! Microvolt T-Wave AlternansTM for Q-Stress combines the industry’s leading cardiac stress test system with Cambridge Heart’s unique Microvolt T-Wave Alternans (MTWA) testing system, creating the most comprehensive, reimbursable cardiac risk-profiling system in the industry (US only). The Analytic Spectral Method® (ASM) detects every-other-beat patterns unique to patients at increased risk by analyzing the ECG in the frequency or spectral domain. Data shows that using frequency is superior at filtering out noise and artifact than using timing alone. The Q-Stress cardiac stress test with treadmill system is designed with you in mind. Its easy-to-learn left-to-right workflow and simple-to-understand icons and intuitive controls guide technicians through the stress test. Busy stress labs use QuikLists to enter comments quickly and efficiently. Our proprietary algorithm, baseline wander, and motion artifact filters reduce noise and produce clean ECG tracings even at high speeds and steep grades. Perfect for pharmacological stress tests as well. Patients will appreciate getting the best test results the first time. And Q-Stress is HL7 and DICOM compatible! Q-Stress has the flexibility to connect to your Healthcare IT systems in the way that works best for you to enhance your clinical workflow.
1ReplyFri Oct 24 2025 | I need help I have a Q-Stress treadmill. The computer was damaged by high voltage. We replaced it, but I can't find the program. Can someone help me with a version for the treadmill? Please, I need help urgently. Reply |
0RepliesSat Jul 20 2024 | Max HR setting So, during the exercise it is showing on the screen, for example 92 % MAX HR. However, when the report prints, it reads, 79% MAX HR..... I am looking to see it there is a setting or something that can be changed to fix this so it matches... Reply |
2RepliesThu Aug 03 2023 | Extended View Can the Quinton Q-Stress be programmed to capture a 12-Lead ECG q1min x 5min's in the recovery phase (after the Treadmill) Reply |
