Sysmex - XS 800i
by Sysmex
Hematology Analyzer
Fully automated Fluorescence Flow Cytometry-Based 5-part Differential Haematology Analyzer with 24 Parameters The Sysmex XS-series is one of the most compact fully automated 5-part differential hematology analyzers available in its class today. It gives accurate results at a price affordable for laboratory budgets, employing the highly advanced Fluorescence Flow Cytometry. Sysmex instruments stand out in terms of quality, and in terms of ease of use. We know just how tough it is to work in a lab all day. So it’s important to us that our devices make your life as easy as possible. At the end of the day, you don't want to have to wait for a complicated shutdown process. Building on our knowledge from the XE- and XT-series, we have managed to reduce user maintenance for the XS-series even further. Now, all you need is a single push of the button to initiate your daily fully automatic shutdown. It takes just two to three minutes. And requires no additional reagent.
You will find other functions and the software menu structure intuitive and simpler to use than in most other analysers. Since XS-800i uses the same reagents as larger X-Class systems, and its operation and user interface are very similar, it is excellent as a nightshift or backup solution. No extra training is required for those used to using the larger devices.
0RepliesWed Sep 23 2020 | instrument was not working switch on the instrument orange light blink & off. Reply |
0RepliesFri Apr 21 2017 | cbc sysmex hi every one i need service manual of xs 800 i sysmex , please send amrokhalifa2004@gmail.comReply |
0RepliesSat Dec 17 2016 | web service For Sysmex XS 800i I have - Sysmex XS 800i - Sysmex xn 1000 - Sysmex ca1500 and I need web service to Integrate with output data of these machines Reply |
| Height | 20 in |
| Length | 16 in |
| Weight | 53 lbs |
| Width | 13 in |
