Sysmex - CA 560
by Sysmex
Coagulation Analyzer
The Sysmex CA-560 System is a compact, fully automated in vitro diagnostic instrument capable of analyzing up to 5 coagulation parameters, simultaneously. In addition, it offers a number of functions including preferential processing of STAT samples and a built-in quality control function. Moreover, it allows analyzed data to be displayed or printed with reaction curves, thus making it possible to obtain highly reliable results. The Sysmex® CA-500 Series is compact, fully-automated systems featuring immunologic*, coagulation and chromogenic measurements in true random access. These five-parameter coagulation analyzers are designed primarily for use in low-volume laboratories or as a backup instrument to larger Sysmex® instruments.
0RepliesThu Apr 10 2014 | Vacuum Pump Error and Sampling Error Position We have plenty all version instruments with serial number AXXX for the models CA560 with SW version 00-17. In the most of the case I do the clean procedure of the Nozzle, clean and lubricate the mechanicals parts special the Z movement. Change the parts is not the solution (PCB, cable and Nozzle) for resolve this matter. So I need to know is something regarding up-dates of the instruments. Reply |
| Height | 19 in |
| Length | 19 in |
| Weight | 99 lbs |
| Width | 21 in |
