Olympus - TJF-160VF
by Olympus
Equipped with Olympus’ new and innovative V-Groove, the revolutionary TJF-160VF makes it easier to perform device manipulation and exchange during ERCP with confidence and efficiency. The unique V-Groove on the elevator of the V-Scope allows it to be raised at a sharper angle than a conventional scope elevator, while securely locking the guidewire in position. Olympus’ new guidewire - the LinearGuide-V™ - has been specifically designed for use with the TJF-160-VF and makes device guidance during ERCP remarkably easy. The V-Scope is an integral part of Olympus’ new V-System™ - the first system integrating precision-engineered endoscopes and EndoTherapy accessories. The proprietary V-System design is built for simplicity; employing the unique V-Groove which locks the guidewire at the elevator, allowing for easier device exchange. Offering the choice between physician or assistant manipulation of accessories, the V-System delivers simple control of the guidewire and device, easy catheter exchange and enhanced cannulation. V-Scope + V-EndoTherapy = V-System™ That’s the power of one integrated system. The V-System™. Only from Olympus.
[list][*] Innovative V-Groove forceps elevator offers reliable duodenoscopic treatment capability when combined with dedicated V-System ERCP devices. [*] Control section with new easy-to-access knob layout and ergonomic grip for improved scope maneuverability. [*] Wide 4.2mm diameter channel. [*] Slim 11.3mm insertion tube. [*] 4-way angulation (120-degrees up, 90-degrees down, 110-degrees right, and 90-degress left) facilitates approach to the papilla of Vater. [*] Fully compatible with the CV-160 and CV-140. [*] Scope ID function stores individual scope information and displays it on the monitor to facilitate endoscopy suite management. [/list]
Olympus Corporation of the Americas (Olympus) has issued updated, validated manual reprocessing instructions for the TJF-160F and TJF-160VF duodenoscope models (160 F/VF duodenoscope models) to replace those provided in the original device labeling.
