Philips - HeartStart FR3
by Philips
Defibrillator
The HeartStart FR3 is Philips best professional-grade AED with advanced features for the professional responder. The FR3 reduces deployment time by eliminating steps and helps you start the right therapy on your patient faster.        The HeartStart FR3 automatically powers on when you open the carry case so you can focus on pad placement. Pre-connected peel and place SMART Pads III, with no foil pouch to open, reduce deployment time.         As the smallest and lightest professional-grade AED available among leading global manufacturers, the HeartStart FR3 weighs only 3.5lbs (1.6kg). It is designed to be rugged, reliable, and ready to use.
-Elijah79
10 months ago
FR3 Battery percentage.
Hello,
Hope you are well.
I have an FR3 AED which is in good condition. However is there a way to see the exact percentage of the battery remaining? For example the FR2+ it states on the menu counting backwards how much charge is left. For example if it says 2% that means that the battery has 98% remaining.
SERVICE COMPANIESView All Defibrillator Companies
  • Easy to Use - The FR3 is fast to use with peel and place SMART Pads III that are suitable for adults and children
  • Built for Endurance and Flexibility - Tested to the stringent military standards, meets IP55 rating for protection against dust and jetting water, and passes a 1,100 pound crush test
  • Rich Clinical Information - FR3 delivers patient-specific guidance for the most appropriate initial therapy. For non-cardiac arrest patients, using the 3-Lead ECG cable helps you assess their condition.
Height13.4 in
Length 7.7 in
Weight13.2 lbs base unit with 1 battery/pads and pads cable
Defibrillator TypeExternal, Automated (AED)
Width12.4 in
NEWSView All
Philips HeartStart FR3 earns U.S. Army Airworthiness...
Philips received an Airworthiness Release (AWR) Certification for its HeartStart FR3 automated external defibrillator (AED) from the U.S. Army.
FDA AlertsView All
Class 1 Recall: Heart Sync, Multi-function Defibrillation...
A recall has been issued for Heart Sync, Multi-function Defibrillation Electrodes because they will not work with Philips FR3 and FRx AEDs. Philips made changes to the connector design of their FR3 and FRx AEDs, and because of these changes, the
This recall was updated on January 8, 2015.
Class 1 Recall: CONMED Corporation, PadPro and R2 Multi-Function...
Philips made changes to the connector design of their FR3 and FRx AEDs. Because of these changes, the CONMED electrodes will no longer work with these AEDs.
