Defibtech - Lifeline View
Defibrillator
The Lifeline VIEW AED is the first and only AED with a full-color interactive display that shows step-by-step videos for performing CPR, rescue breathing and external defibrillation. The Lifeline VIEW AED also has clear, calm voice prompts as well as on-screen text prompts, effectively providing three modes of instruction. The AED Status Screen displays essential status information and the Maintenance Mode permits the user to perform maintenance related actions as well as change unit parameters. The unit has a brightly lit status indicator and rubberized surfaces.
SERVICE COMPANIESView All Defibrillator Companies
- A Personal Coach - The Lifeline VIEW has a built-in metronome that counts out the beat of the compressions to provide so you know what to do and when to do it
- Real-Time Protocol Selection - Allows you to switchover from compression-only CPR to compression and rescue breathing CPR without skipping a beat
- Ruggedness & Durability - The VIEW's ruggedness is measured by demanding environmental tests
- Easy to Maintain - The status screen gives you up to the minute information on maintenance if it's required
- Device Ready for Rescue - Lifeline VIEW's one touch status screen gives you everything you need to know that the unit is up to date and in working order without turning it on
Defibrillator Type | External, Automated (AED) |
