AGFA - Drystar 2000C Dry Imager
by AGFA
The Agfa Drystar 2000C System, a unique imaging system consisting of the Drystar 2000C dry imager and Drystar films, is convenient, networkable and ecological. Agfa Drystar dry imaging films are designed to produce the very highest diagnostic quality grayscale and/or color hardcopies generated by the Agfa Drystar 2000C imager. Agfa 2000C is state of the art in dry technology for diagnostic imaging. The AGFA 2000C imager for grayscale and color hardcopy imaging is the 8x10" imager of choice. Color imaging The laser-like image quality of Drystar TS color imaging films is thanks to Agfa's unique "Color Tuning" system, patent pending, which assures optimal print-tomonitor matching by using built-in compensation and calibration mechanisms. Color hardcopies provide essential diagnostic information for C-arm, Ultrasound, NM, and 3-D CT and MRI workstations. The AGFA 2000C can be changed from grayscale to color or vice-versa within seconds. Grayscale imaging A breakthrough in dry grayscale imaging, AGFA Drystar TM grayscale imaging films feature exceptionally high density and contrast and are indistinguishable from laser films. AGFA Drystar TM films produce crisp, stable images with the same "look and feel" as conventional film. Made of 175 um PET, AGFA Drystar TM films are designed for light box viewing. The AGFA Drystar 2000 is convenient Dry technology for printing diagnostic quality hardcopies in full daylight offers tremendous advantages. No chemistry, no processors, no darkroom and no expensive chemical disposal costs. Its compact size means it can be placed on a table-top or in mobile applications, or wherever it is most convenient for optimum diagnosis. The Drystar 2000 is ecological With dry imaging - no chemicals or plumbing are needed. Agfa has taken special measures to reduce the amount of packaging material, and to assure that the packing which is used can be recycled after it has served its purpose. All plastic parts are specially marked, to assure efficient recycling of used units. The Drystar 2000 is networkable Thanks to its modular concept, the Drystar 2000 can operate in both point-to-point or in an Impax network environment. The newest link in the Impax open network imaging chain, the Drystar 2000 offers "plug-in" networking. It can be connected anywhere on the network by means of a simple and inexpensive upgrade kit. No waiting The AGFA Drystar 2000 digital imager features built-in image spooling on an internal hard disk. This means high throughput because lock-out time is virtually eliminated. Black & white films require only 70 seconds, and color films 4 1/2 minutes (8x10") for the first prints, the second prints require even less. Choice of interfaces The modular design offers optimal application to your specific imaging and networking requirements. A wide variety of interfaces are available including video (LLR to UHLR) to digital, Ethernet (DICOM 3.0 / TCP/IP) and SCSI.
0RepliesThu Oct 17 2019 | power supply module fault drystar 5302 power supply module is not working how i can repair it , please let me know the procedure so i can troubleshoot and find out which components are faulty , and how i can repair it . Reply |
1ReplyFri Apr 05 2013 | ribbon Hi! I am Nuclear Medicine physician in Greece. I' m searching ribbon for AGFA Drystar (IMPAX). Could you help me? e-mail: jtkoutsik@yahoo.gr Reply |
Standard features :[list][*] printing of full color and grayscale images on 175um PET base [*] image spooling on internal hard disk [*] multiple film layouts including: 1/1, 2/1, 4/1, 6/1 and 9/1 & super slides [*] importing and exporting of TIFF images [*] split mode option - automatic routing of all color images to the Drystar 2000 and all grayscale images to an LR 3300 Laser Imager [*] optical resolution : 300 dpi (identical to the LR 3300 Laser Imager) [*] 256 gray levels - 16.7 million colors - maximum optical density : 3.0 for TM 1 B grayscale films 2.0 for TS color films [*] patented color saturation matching system to reduce image artefacts [*] standard internal keypad, display and foot-switch Drystar TS films : [*] Donor ribbons : delivered in a handy, recyclable loading box each ribbon allows 100 hard copy prints [*] Acceptor sheets (8x10" on a 175um PET base): clear base Drystar TS 2 C blue base Drystar TS 2 B opaque base Drystar TS 2 0 Drystar TM films : [*] 100 films per box [*] blue base - 8x10" [*] delivered in a handy, recyclable loading box [/list]
