Conmed - System 7550 with ABC
by Conmed
The System 7550™ with ABC® Technology allows physicians to bring the art of surgery to new levels. By utilizing this full-powered electrosurgical generator featuring argon beam coagulation, surgeons are able to achieve rapid hemostasis resulting in: [list] [*] Reduced blood loss [*] Reduced surgical time [*] Reduced surgical plume. [/list]
2RepliesFri Mar 16 2018 | sterilization of extension adapter The sterilization instructions for (connector for the argon probe) Ref # 133000, states the only sterilization method is to use the Steris VHP system. We along with I'm sure other facilities do not have this system available for this sterilization. What are other facilities using for their sterilization of this adapter. I am confident there must be an alternative sterilization method.Reply |
1ReplyTue Dec 19 2017 | Manual Is there an operators manual for this machine? Reply |
1ReplyThu Dec 29 2016 | Is there any periodic PM recommendation? I have not been able to find any manufacturer recommended PM for this equipment. There is maintenance for initial testing prior to first use, but the service manual fails to set any recurring checks or tests. Are there any other documents that set a PM for this item? Thanks. Chris. REF: SYSTEM 7550 ELECTROSURGICAL GENERATOR + ABC MODES Reply |
Surgeons also benefit from the System 7550™’s state-of-the-art technology including: [list] [*] Remote power control [*] Pulse cut [*] Programmable specialty modes [*] Patient safety precautionary features [*] Clinical results. [/list] Because of its powerful capabilities, surgeons prefer this electrosurgical generator in a number of procedures including open, laparoscopy, and gastroenterology.
| Height | 41 in |
| Length | 25 in |
| Weight | 110 lbs |
| OutPut Frequency | 461 kHz |
| Width | 24 in |
System 7550™ ABC® ESU and Base, 110V, 60Hz 60-7550-120 System 7550™ ABC® ESU and Base, 230V, 50Hz/60Hz 60-7550-230
