Medline - BioCon CUBEscan 700
by Medline
Bladder Scanner with Printer
FORUMSView All (3)
-Aileen C.
5 months ago
I need to match my probe to the scanner Error code E008-- Please help!
I purchased a used Scanner 700 and need to match my existing probe but keep getting error code E008.
-CarlAnderson
2 years ago
Charging Cable disconnects frequently
Does anyone have a simple solution to prevent the charging cable from falling out of the side of the scanner? I am meaning the small dc cord not the power cord. Easily the biggest problem that we see with this unit is the "battery not holding a charge" which have all been due to the cable not being attached and the staff not noticing. These are mounted on a roll stand and not removed ever so a fixed solution would probably be ok.
-AR
5 years ago
Biocon starts scanning on it's own.
We have two BioCon 700's that start scanning before the scan button is pushed. Is there a setting that needs to be changed? It seems odd that both devices have the same problem. Reply
[list]          [*] Compact and portable, the 3-D ultrasound device provides quick, safe and non-invasive measurements of bladder volume and post-void urinary retention (PVR).          [*] Real-time pre-scan helps improve accuracy, reduce improper scans and save time by viewing the bladder before performing the test.          [*] Built-in printer facilitates immediate documentation in the chart              [*] 7" TFT-LCD (WVGA) full-color touch screen    [/list]
Dimensions: 7.95"W x 2.6"L x 4"H
