STERIS - SYSTEM 1E
by STERIS
Integral in the perioperative loop, SYSTEM 1E Liquid Chemical Sterilant Processing System is designed to improve the flow of the OR with minimal costly inventory and increased productivity, allowing maximum surgical procedures with reduced resources. In 23-minutes, you're ready for the next procedure. Liquid chemical sterilization provides fast reprocessing ease for cleaned, reusable, immersible, and heat-sensitive critical and semi-critical devices. S40™ Sterilant Concentrate is a powerful liquid chemical sterilant that eliminates all microbial life. Its compact footprint makes SYSTEM 1E processor convenient and ideal for a variety of locations. The use-dilution is neutral pH, and rinses safely down the drain. The SYSTEM 1E processor performs two quick rinse cycles, reducing energy and water consumption. Running a 23-minute cycle, the SYSTEM 1E processor minimizes device downtime between patients. Two pre-filters, UV irradiation and a MaxPure™ filter work in harmony with S40 Sterilant Concentrate as a validated process for critical and semi-critical, heat sensitive devices. This gentle use-dilution protects delicate surgical instruments, including multi-channel flexible surgical endoscopes. Providing a high standard of patient care, whether it’s in your OR or GI department, the SYSTEM 1E processor will help you process your devices with confidence.
2RepliesFri Aug 27 2021 | Pm part cost Anyone know the cost of pm parts on these units per year? Even ballpark will work. Thanks Reply |
2RepliesTue May 01 2018 | service / repair manual I have this error coming intermittently " circulation pressure low " Reply |
1ReplyFri Mar 02 2018 | REPLACEMENT FILTER HOUSING NO LONGER SUPPORTED... PART # 400356. Is this CUNO filter housing available ?Reply |
[list] [*] From the Substerile to the Surgeon in Only 23 Minutes* [*] Increased productivity - Simple, 3 step process [*] Maximize utilization of devices. Minimize downtime & repair. [*] Environmentally friendlier solutions [*] From the trusted innovator and leader in liquid chemical sterilization [/list]
