Sorvall - Discovery 100SE
UltraCentrifugeWith speeds up to 100,000 rpm, the Sorvall Discovery 100SE Ultracentrifuge offers unsurpassed performance. All the advanced features come with top-of-the-line performance, powerful functionality, and revolutionary ease of use, all built into the smallest, quietest, floor model ultra on the market.
FORUMSView All (4)
0Replies3 years ago | Wont hold vacuum Centrifuge wont hold vacuum have checked pumps and hoses it seems to be loosing it in the chamber somewhere any ideas? Reply |
1Reply7 years ago | E13 error message Sorvall Discovery 100: I have an E13 error message. How can I resolve it?Reply |
1Reply7 years ago | Rotor alarm I put the rotor in (surespin 630) and set the rotor from RLM. But the run screen always show rotor alarm. I cannot start spin. Reply |
[list] [*] Maximum speed of 100,000rpm (802,006 x g) [*] Simple keypad and large LCD display for easy set-up of routine spins . Control panel is simple with easy key operation and easy-to-see liquid crystal screen. [*] The displayed language can be switched over between English and Japanese [*] The real-time control (RTC) feature enables setting a start time or a finish time, thus letting you run your machine at a desired date and time. [*] Centrifugal force (RCFmax and RCFavg) can be displayed and set. [*] Twenty varieties of nine stepped modes can be programmed for a wide range of applications. [*] Various alarms notify users of causes and necessary actions when fault conditions are detected allowing easier and quicker troubleshooting. [*] Low noise level makes the ultracentrifuge suitable for use in any laboratory. [*] Samples can be easily balanced visually. [*] CFC-free thermoelectric cooling system with greater cooling capacity. [/list]
Orientation | Benchtop |
Centrifuge Type | Ultraspeed |
Maximum Speed | 100000 rpm |
