GE HealthCare - Precision 500 D
by GE HealthCare
It starts with the imaging chain, which features a 12-bit CCD-based camera.Then there’s AutoEx, which automatically adjusts key image-acquisition parameters in real time for optimum quality. Meanwhile, closed-loop Automatic Brightness Control and patented extended Dynamic Range circuitry maintain contrast and minimize blooming.
0RepliesThu Apr 02 2026 | Rcim2 communication Failure. Already replaced RCIM2, cabling, HP computer, corona, lime, re-downloaded Lennox. reconfigured off a working unit across the hall plugged the ethernet directly into the Saturn. Directly plugged the RCIM2 into the Corona board. 500-0053 error code. I’m at a loss. Only happens while floroing. Equipment: GE P500D Reply |
0RepliesMon Dec 19 2022 | Generator error 3601163 Generator error 3601163 is being triggered everytime I try to use the large focal spot. I already measured resistance and continuity directly into the tube and also in the generator side to make sure cables are ok as well. They are just fine. I also did what the manual says, I replaced the heater board and it is still the same. Does anyone have a recommendation?Reply |
0RepliesThu Aug 25 2022 | table angulation Have an isse with table angulation at zero deg reference, not consistant, motr, pot, board and MRAS controller all have been changed out, loaded software and backups. any ideas? Equipment: GE Healthcare - Precision 500 D Reply |
[list] [*] Ergonomic SMART Handle table positioning and tube controls enhance productivity and patient comfort. [*] Automated dose and image management tools reduce radiation to help protect both patient and technician. [*] 12-bit CCD-based camera, 1024 x 1024 imaging matrix and the Fluoro Noise Reduction (FNR) algorithm combine to create an imaging chain that produces images of extraordinary clarity. [/list]
| Maximum Focal Spot | 73.5 in |
| Height | 34.8 in |
| Length | 83.9 in |
| X-ray Generator Power Rating | 80 Kw |
| Motorized Tilting/Pivot Rotation | 90 |
| Width | 28.3 in |
