Medical Illumination - Centurion
by Medical Illumination
The standard Centurion is a mid-range surgery light which offers similar performance and features found on higher-priced surgery lights.
The standard Centurion is a mid-range surgery light which offers similar performance and features found on higher-priced surgery lights. It includes a highly efficient, single reflector design, assuring optimal shadow reduction, and the same flexibility found with all arm designs for the 21st Century series.
FORUMSView All (5)
-mille600
a year ago
model number 021514
I am trying to find the service manual for this surgical light and cannot find it, I am trying to find out of the light has higher settings and how to use them. Thanks Michelle
Equipment: medical illumination Centurion
-srseng
3 years ago
weight
replacing fixture what is the weight of fixture (arm and head)?Reply
-jkgordon1
7 years ago
cleaning behind the lens
Medical illunmination Surgical lamp Model 021515
We have broken bulb debris inside the head.  What is the propeer technique for cleaning behind the lens?
thank you
Joe
[list]      [*] Color correcting, heat-absorbing glass cylinder      [*] Lamp head and arm both rotate 540 degrees      [*] Arm moves 40 degrees up and down from horizontal plane      [*] Standard removable, sterilizable handle      [*] Available in a wide variety of mounting/combination options      [*] 28" (711 mm) articulating arm with adjustable compression spring      [/list]
Bulb Life2000 hr
Depth of Field42 in
Color Temperature4000 K
Lighthead Diameter16.5 in
Field Diameter5.61 in
Output at 1 meter = 15" diameter reflector with 4,000 ft candles (43,000 lux)      Pre-focused 6" (150mm) spot = 1 meter distance
