Toshiba - Asteion 4
by Toshiba
The Toshiba Asteion Multi 4 is the only 4-slice of it's kind capable of tilted helical scanning. Scanning has never been as easy as with the new high efficiency Guided Mode. The Guided Mode gives experienced users the possibility to scan even more efficiently and allows new users to get quickly get acquainted with the Asteion Multi 4 system. Ask one of our experienced representatives for additional details of this system’s features.
0RepliesThu Sep 29 2022 | Error Error in RECON unit (time out) call service Code [0*00000002] dev[0*00020000] pno[1] Error in RECON unit (time out) Code [0*00000002] dev[0*00020000] pno[1] Equipment: Toshiba - Asteion 4 Reply |
2RepliesMon Jun 27 2022 | Error in Gantry Rotation TOSHIBA ASTEION SUPER4 CT SCANNER ERROR Error in Gantry Rotation : ( 0*b1360008) dev(0*00010001) Pno(0) My whasapp +237666561861 Reply |
6RepliesSun Feb 27 2022 | Asteion 4 CT Hi, I have problem massage, error in guaranty rotation code 0xb 1360008, also the warm up is very slow, can you advise please Reply |
[list] [*] Real-Time Helical Scanning [*] 1800mm Scan Range [*] 3D Imaging Capabilities [/list]
| Type (configuration) | Multislice |
| Slices | 4 |
| Gantry (Max. Clearance) | 72 cm |
