Siemens - CLINITEK 50
by Siemens
Urine Analyzer
The Bayer Clinitek 50 is a urine chemistry analyzer designed to meet clinical urine tests for health care centers, physician offices, and small laboratories. With a throughput of 50 samples per hour and processing time within five minutes, the Clinitek 50 saves time and increases productivity. The system also offers low-cost, versatile and reliable operation as it determines urine color, and distinguishes between intact red blood cells and hemolyzed occult blood.    Compact, lightweight and portable, the Bayer Clinitek 50 urine chemistry analyzer only weighs 3 lbs. and measures 9.2" D x 6.0" W x 6.1" H. It also provides a 50-result memory for transfer to a computer, and operates on line power with optional battery pack for alternate site operation.    The Bayer analyzer uses Multistix 10 SG Reagent Strips for performing traditional urinalysis. Bayer Clinitek 50 analyzers are also capable of performing Multistix PRO and Clinitek micro albumin/creatinine analyses. It is also possible to achieve results in formats of your choice with the time and date stamped.
FORUMSView All (9)
-DianneC
4 years ago
No results on paper
How can you repair the printer? The heat sensitive paper feeds correctly but no results are displayed. The instrument does provide results because they can be viewed, just not printing on paper.Reply
3
-Steven Bradley
5 years ago
Error 3
Does anyone know what would cause/ what the fix for an error 3 message is? I see that none of these have replies yet, so if i discover this myself I'll add it to the tread myself. All that being said, if you have an answer please educate me.Reply
-Clintek 50
7 years ago
I'm getting error 4 on machine.
When I put my strip in this morning it went in but did not come back out. I have cut machine off and cut it back on. Nothing is happening. What should I do now?Reply
  • Compact, lightweight and portable
  • Results reported in formats of your choice
  • Multiple reporting options
  • Optional battery pack provides 200-test capacity
Height15.5 in
Length 23.5 in
Weight1.42 kg
Width15.2 in
