Beckman Coulter - DU-730
by Beckman Coulter
Spectrometer
The instrument has an optical grating for wavelength selection and two silicon photo cells as detectors. The instrument provides a touch screen used to operate the system. The screen displays labeled keys, which become active when touched. The instrument highlights the activated key and performs the corresponding command. The DU Series 700 Spectro photometer is a single beam photometer with a reference beam, used to take measurements in the wavelength range from 190 nm
0Replies7 years ago | Beckman Coulter DU-720 self-check stopped,please check the lamp
after turn on the machine, its showed "self-check stopped,please check the lamp" what's the problem? Reply |
0Replies7 years ago | Sales Office in Iceland for Beckman Coulter Products? I would like to send our Beckman Coulter DU-730 Spectrophotometer to get it overhauled. Cleaned and repaired, if needed. Do you have a sales office in Iceland? Reply |
CSV File Format for Data Transfer
USB Ports
Spectral Bandwidth of 3.0 nm
Touch-Screen User Interface
Operator and Sample ID's
Wavelength Range from 190 to 1100 nm
Focused Beam Design
Quick Interchange of Cell Holders & Modules
Password Protection with Security List
Automatic Lamp Turn-Off
Height | 200 mm |
Length | 200 mm |
Weight | 15.5 kg |
Width | 500 mm |
