Philips - SureSigns VS4
Taking vital signs to the next level — the SureSigns VS4Get more from vital signs monitoring with the Philips SureSigns VS4. Respond to changing patient conditions by having the versatility to choose between NBP interval mode and spot check mode in the same device. Simplify clinician workflow with an intuitive touch-screen interface and tools like QuickCapture and QuickCheck. Wireless capability and the proactive monitoring tool QuickAlert supports your hospital’s Rapid Response team. The VS4 is simple to use and works easily with your existing network. It provides you with peace of mind and flexibility — all in a package that’s as easy to love as it is to use.
FORUMSView All (8)
1Reply4 months ago | Firmware not loaded How do I fix this problem Reply |
2Replies6 months ago | service no display back light working Equipment: Philips - SureSigns VS4 Reply |
2Replies4 years ago | Blue screen I have 2 Philips VS4s that have a blank blue screen after you try to take blood pressure..unit loads up fine and goes to home screen but once you try to take blood pressure the screen goes blue..is this a board issue?Reply |
[list] [*] Touch screen – color LED backlit screen. [*] Internal WiFi / 802.11 a/b/g option. [*] QuickCheck: - Care giver authentication at the bedside. - Patient record validation at the bedside. - Patient record review before export to EHR. [*] QuickCapture: - Customize up to 20 observations and assessments entries. [*] QuickAlerts: - Supports Hospital Rapid Response Systems. [*] Additional ease of use enhancements for your IT and network informatics teams and your caregivers. [*] 2D bar-code scanner programmable for multiple ID fields. [*] Time-sync with hospital or network clock. [*] Improved battery management, including a clearly visable icon to show unit is plugged in and charging. [*] Confirmation of exported records easily seen in green. [*] Clearly identifiable one-touch NBP on/off button. [*] Stores up to 800 patient records. [/list]
Height | 8.6 in |
Length | 5.7 in |
Pulse Rate Range | 30-300 BPM |
Weight | 6.9 lbs |
SpO2 Range | 0-100% |
Temperature Range | 91.4 to 107.6 °F |
Width | 10.2 in |
