Ohio Medical - Isoflurane Vaporizer
This product is Discontinued
The vaporizers are designed for "out of circuit" use in continuous flow techniques of inhalation anaesthesia.The vaporizers are temperature and flow compensated so that their output remains relatively constant despite cooling due to vaporization and variations in inlet flow. Each vaporer is clearly labeled with the name of the anaesthetic agent for which it is designed.
1Reply8 years ago | Sannom I asm looking for a Isoflurane vaporizer 100F diagram with the parts names and numbers Thank-you Christian Caritey Reply |
[list] [*]Flowrate Compensation [*]Temperature Compensation [*]Detents at 1/4% up to 2% on the dial [*]225cc Capacity [/list]
