Instrumentarium - ORTHOPANTOMOGRAPH OP300
by Instrumentarium
ORTHOPANTOMOGRAPH® OP300 is the most comprehensive 3-in-1 platform designed for today and tomorrow. OP300 combines an advanced panoramic imaging system with either cephalometric or cone beam 3D or a combination of both, giving you a truly adaptable platform. In addition, all of these options can be upgraded in the field after the initial purchase.
2RepliesSun Jul 13 2025 | MANUAL DE SERVICIO DEL ORTOPANTOMOGRAFO PANOURA 16 D mi equipo esta dando eror 6 LO , no tengo manual por lo qe no se a que se refiere , el equipo se enciende comienza a girar el cabezal y se frena, continua girando y luego se vuelve a frenar y te da este error. Equipment: Ortopantomografo O RAYOS X PANORAMICO DENTAL PANOURA 16D Translation:My equipment is giving error 6 LO, I don't have a manual so I don't know what it refers to, the equipment turns on, the head starts to rotate and stops, it continues rotating and then stops again and gives you this error. Equipment: Orthopantomograph OR DENTAL PANORAMIC X-RAYS PANOURA 16D Reply |
