Philips - Agilent M4735a
by Philips
Defibrillator
Ligthweight, easy-to-use defibrillator/monitor with both Manual and AED capabilities.
2Replies8 years ago | Battery LED is out Hope someone can help me, I have replaced the front bezel as per Philips Tech Support to remedy the battery charge LED not illuminating. Once the bezel was replaced, I still have the same problem, the defibrillator functions perfectly with the exception of the LED. Any further guidance would be extremely helpful.Reply |
0Replies9 years ago | circuit diagram philips heartstart xl Dear friends if any body have circuit diagram of philips heartstart defibrillator. Thanks Reply |
2Replies11 years ago | Functional test How to do daily functional check for Philips HeartSmart XL biphasic defibrillator machine? Reply |
Height | 19 cm |
Length | 34.6 cm |
Weight | 6 kg |
Defibrillator Type | External, Automated (AED) |
Width | 37.6 cm |
