Unfors RaySafe - X2
by Unfors RaySafe
Life is busier. There are more demands on your time. So you need to remove the unnecessary steps in taking a measurement. Like positioning the sensor, choosing a setting, or interpreting the results. Fortunately, the X2 R/F sensor is orientation independent so the only thing you need to do is to place it in the X-ray beam and turn on the instrument. The rest is automatic – no menus, no selections. The large, intuitive touch screen of the RaySafe X2 provides more insight with an easy-to-read display of parameters and waveforms. More in-depth information is only a swipe away.
0Replies4 years ago | General C-arm testing ideas and advice Hi, I'm relatively new to imaging and I was wondering if anyone could share some ideas on things that should be checked when doing C-arm PMs. Here's what I have for test equipment/phantoms available: - Raysafe X2 meter (I use this with the Raysafe View software and their excel template when testing my overhead rooms) - Gammex 141 high contrast resolution test tool - 2 different line pair phantoms What I would be really interested in is an excel template similar to the Raysafe one I use for my overhead rooms that is set up specifically for fluoro testing... I don't think Raysafe offers one specifically for fluoro. Thanks! Reply |
0Replies7 years ago | RaySafe X2 - Sensor Positioning with the FlexiStand Instructional video demonstration on how to position the sensor with the RaySafe FlexiStand.Reply |
0Replies7 years ago | X2 - Measuring with the MAM Sensor The X2 MAM sensor possesses state-of-the-art precision in dose and HVL that enables the user to obtain important readings without any pre-knowledge of the mammography machine.Reply |
[list] [*] Full range - for range for R/F and mAs applications [*] X2 sensors - provides unsurpassed accuracy, reproducibility and sensitivity [*] Touch screen interface - allows the user to view data in a comprehensive yet flexible way [/list]
Height | 34 mm |
Length | 85 mm |
Weight | 521 g |
Analyzer/Simulator Type | X-ray Measurement System |
Width | 154 mm |
Battery Life: 10 hours intensive usage Display: 4.3" LCD with capacitive touch
Unfors RaySafe, a Fluke Biomedical company, unveils a new Survey sensor for the RaySafe X2
