Medison - SonoAce 6000
The Medison SonoAce 6000 ultrasound system is a scanner that features many elements that make it a great addition to many medical settings.Medisons SonoAce 6000 ultrasound has excellent image quality and a good image filing system. It also features an easy-to-use, ergonomically designed keyboard that is well-lit for optimal use in a dark room.
FORUMSView All (10)
2Replies4 years ago | Probe going dark I have a sonoace 6000...the probe goes dark after booting.... Help pls Reply |
1Reply4 years ago | Configure kernal parameters Please what can be the solution if medison SA6000II is showing configure kernel parameters when booting?Reply |
0Replies4 years ago | Technical problem I have a medison 6000II, sonoace 128 prime that is having booting problems. The booting is incomplete. Usually stops at configure kernel parameters. Is it a software problem? If yes, can i be assisted with the software for reloading. Thanks Reply |
- Linux operating system
- Linear and curved linear capable zoon
- Harmonic imaging
- 3D surface rendering
- Spectral PW Doppler
- M-mode
- Cine and Zoom
- Dual probe connect/switch
- OB/GYN, fertility, urology, and vascular calcs/reports software
- sonoView Lite image management archive
- 200GB hard drive and magneto optical disc drive
- Black and White
- Smaller platform system
Cart Based | 1 |
Clinical Applications | OBGYN |
Image Display | 12 in |
