Baxter - Gambro Prismaflex System
Flexibility that meets the strict demands of multiple blood purification therapies.
Deliver a complete range of continuous extracorporeal blood therapies with a highly versatile platform that can be customized to specific patient needs. Safe and easy to use, the Prismaflex system is your single solution for multiple intensive care therapies.
3Replies7 years ago | Specification and Availability Does the Prismaflex system require water hook-up and/or drain? Is it available in the United StatesReply |
1Reply11 years ago | PrismaFlex gambro Please, how calibrate sacle of Prismaflex Gambro Thank you, Sergio- São Paulo Brasil Reply |
[list] [*] A single system for all CRRT therapies, including SCUF, CVVH, CVVHD, CVVHDF, and TPE [*] Industry-leading fluid management accuracy [*] Integrated design functions for effective anticoagulation management [*] Convenient and simple oversight of pre- and post-dilution mixing points through two integrated pinch clamps [*] Multiple fluid therapeutic combinations and optimum dose delivery capabilities through a high flow-rate pump and four fluid pumps [/list]
Height | 64 in |
Length | 12 in |
Weight | 132 lbs |
Width | 19 in |
