Burton Medical Products - AIM-50
by Burton Medical Products
Burton's new AIM-50™ provides both amazing illumination, unparalleled aesthetics and many more features that make it the right light for any procedure
Burton's new AIM-50™ provides both amazing illumination, unparalleled aesthetics and many more features that make it the right light for any procedure. Ideal for long hours of use with three cool 50-watt quartz halogen bulbs each rated with a 2000-hour average bulb life.
-vishwas
3 years ago
dissembling of ceiling surgical light
Dear Experts , I am facing problem for dissembling my double arm ceiling surgical light. Model is burton A53DC. I want to dissemble part by part. I am facing difficulties in detaching the arms .There are some washers called safety washer and retain rings . IS there any easy method to remove these washer s?. since it is very thin and congested ,i can not even insert a nose plier .If any one have experience in this , kindly advise me . I am dissembling it because one of the arm lights are not getting ON . I suspect some cables damaged .I need to trouble shoot other things also. Dissembling make my job easier so that i can keep it on floor and continue my investigation . Reply
  • Illumination:45,000 Lux at 36 inches
  • Larger and adjustable light pattern
  • Color temperature: 3100° K
  • CRI (Color Rendering Index): 96
  • Unlimited rotation and maximum reach
  • Y-shaped lighthead
  • Light pattern free of cast shadows
  • On/Off standby switch on the lighthead
Bulb Life20000 hr
Depth of Field47 in
Weight44 lbs
Color Temperature3100 K
Lighthead Diameter20 in
Field Diameter10 in -12"
