VIDAR - DiagnosticPRO Edge
by VIDAR
Takes the high reliability, image quality, and consistency
At double the scanning speed it allows for more studies in half the time. With its DUAL USE function, DiagnosticPRO Edge offers all-in-one flexibility – in addition to PACS it can be used in facilities that now or in the future will support digitization of mammography priors. If you have a file room supporting PACS and low-volume mammography applications, the 44-micron spot size and 4.0 OD DiagnosticPRO Advantage will be key in the digital transition.
| Height | 9 in |
| Detector | Solid-state, next-generation High Definition CCD |
| Diameter | 14.5 |
| Weight | 25 lbs shipping weight: 35 lbs. |
| Clinical Optical Density Range | 0.07 to 4 |
| Width | 18 in |
Film Sizes:
Geometric Accuracy: Better than 1% or 2 pixels, whichever is greater, in both axes
