Dideco - Compact A
by Dideco
Autotransfusion System
The Dideco Compact A (Advanced) is a compact, portable autotransfusion system which utilizes a Latham bowl. It is manufactured by the Dideco unit of Sorin Biomedical in Italy.    [u][b]It is no longer manufactured and was retired in 2009.[/b][/u]
-lausero
Sun Aug 17 2014
dideco compact-A error
Hi, I have a dideco compact advanced cell saver that displays the error "E 24".
Does anybody know what does it mean?? Thanks
Height50 cm
Length 52 cm
Weight36 kg
Width43 cm
Weight transporter: 15 Kg       Voltage: 100-230 V~ (automatic adapter)       Frequency: 50-60 Hz       Rated power: 120 VA (typ)       Fuses: 2 X T3.15A external (replaceable)       Centrifuge speed: 1500:5600 rpm (adjustable)       Pump flow rate: 25:1000 ml/min (adjustable)
