BioSystems - BTS-370 Plus
by BioSystems
The automatic analyzer BTS-370 PLUS for biochemical measurements.
Of Spanish origin, the photometer has an optical system designed by computer software and next-generation multiprocessor with calculations and innovative technology with no internal adjustments by incorporating self-testing and calibration through software. The processing capacity is up to 120 samples and 100 tests per hour.
FORUMSView All (4)
-saulo oliveira
Sat Sep 07 2024
Software !
 I need the software ( Biosystem BTS 370 Plus )to make it run ! If somebody can help me !!
-ING-EBG
Wed Jul 01 2015
monitor spec370b
Best regards, good day.
     In a Spec 370 when turning on the scaner does not initialize properly and puts the analizer display (monitor spec370B).
     The only motors are enrgized the rotor samples, the horizontal movement motor arm and wheel wavelength filters. Therefore not comunication whit the CPU
Un saludo, buen dia.
      En un Spec 370 al momento de encender el analizador no inicializa correctamente y en el display del analizador pone (monitor spec370B)
      Los unicos motores que estan energizados son los del rotor de muestras, el motor de movimiento horizontal del brazo y el de la rueda de filtros de longitudes de onda. Por lo tanto no tiene comunicación con el CPU.
-imy21
Sat Feb 28 2015
problème
j'ai un problème avec ma machine biosystème 370, je ne peut l'installer, il s'affiche un message: imposible d'instraller , machine bio système, standby.
Sample Capacity120
Throughput100 samples/hr
