Conmed - Circon ACMI BiCap II BC-200
by Conmed
Bipolar/Monopolar Electrosurgical Unit
ConMed Circon Corp ACMI BiCap II BC-200 Bipolar/Monopolar Electrosurgical System is proven reliability of solid-state design and for use in GI endoscopy.     BiCap bipolar output has a precision timer helps regulate applications and designed specifically for BiCap bipolar accessories. It is safe and low voltage.     Monopolar and bipolar performs the functions of two generators, and uses minimal space, simplifying setup. It is compatible with most disposable and reusable monopolar accessories.
FORUMSView All (4)
-LisaRB
5 years ago
Operating Manual
Looking for an operating manual for the BC-200 Bicap machineReply
8 years ago
Watet bottle
Was wondering if you sell replacement water bottle For ACMai Bicap 200 unitReply
8 years ago
Replacement watet bottle
[list]  [*] Easy to use interface   [*] Bipolar coag, monopolar cut/blend settings   [*] Durable and easy to clean footswitch   [*] Easy to read power setting indicator   [*] Cable fault alarm   [*] Monopolar connection   [*] 3 bipolar time selectors (1sec, 2 sec, Continuous)   [*] Easy loading pump tubing assembly   [*] Integral fluid pump permits irrigation   [*] 80 ml/min nominal fluid flow rate   [*] Adjustable audio volume   [*] Power adjust knob with accompanying bar graph reading from 0-70 W   [*] Masterflex peristaltic pump head, 7021-24   [*] Instrument power on/off rocker switch with red indicator light   [*] Instrument sits flat or use brace for tilt view   [*] Carrying handle   [/list]
Height5.5 in
Length 14 in
Weight18 lbs
OutPut Frequency60 Hz
Output Power50 W
Width15.5 in
Voltage: 115V (nominal)
