NuAire - PureCell NU-5100
Incubator
The PureCell 5100 Under Counter Direct Heat Laboratory CO2 Incubator features a smaller footprint for controlled in-vivo and in-vitro conditions for experimental biology research through precise humidity, temperature, CO2, sterility, and reliability.
1Reply10 years ago | Service manuel Reply |
3Replies10 years ago | Shuts down at 6c Hello, i need help on; Glacier NU-9668 Upright Large Capacity -86°C Ultra Low Freezer, if any service manuelReply |
- Constant Contamination Control A unique HEPA filtration system filters fresh air into the pump, CO2 gas from tanks or house systems, IR CO2 sensor sample air returning to the change, air between air pump and inner chamber, while continuously filtering the internal chamber to create ISO Class 5 air quality.
- Cleanroom within a Cleanroom Interior chamber is constantly maintained at positive pressure similar to an ISO Class 5 Cleanroom.
- Thermal Conductivity Gas Control Thermal Conductivity (TC) CO2 sensor provides reliable monitoring of CO2 levels.
- Precision of Electronic Microprocessor Controls
- A programmable microcontroller samples input sensors, sets control outputs, and makes necessary corrections to the chamber environments resulting in quick and responsive recovery times.
- Reliability and Protection of Automated and Redundant Back-up Systems A temperature sensor probe, solid-state analyzers, HEPA filtration systems, and status alarms create a dependable, long lasting scientific instrument.
- Critical Cleaning Components Coved corners prevent contaminants from becoming trapped in the chamber. Removable shelves, brackets, and gasket make cleaning simple by cleaning around them or placing them in the autoclave.
- Homogeneous Temperature All 6 sides of the chambers walls feature heating elements surrounded by R5 insulation to provide optimum temperature uniformity in the work chamber.
Height | 30 in |
Length | 23.5 in |
Weight | 135 lbs |
Width | 23 in |
- Chamber Volume -4.4 ft.3 / 125 L
- Temperature Control System
- Range-18°C to 55°C
- Uniformity- ± 0.5°C at 37°C
- Accuracy- ± 0.25°C
- Display Resolution- 0.1°C
- CO2 Control System
- Range- 0.1 to 20%
- Accuracy- ± 0.25%
- Display Resolution- ± 0.1%
