Carestream - LS75
by Carestream
Designed especially for high-resolution teleradiology applications.
The LS75 film digitizer is a high-performance tabletop laser film digitizer designed especially for high-resolution teleradiology applications. It accepts films up to 14 x 17 in. (35 x 43 cm) and offers all the inherent advantages of other CARESTREAM laser film digitizers, including ease of use, excellent density resolution and precision. Self-calibrating and unaffected by ambient light, this digitizer has multiformat software compatibility, easy integration with PACS environments, TWAIN and DICOM modalities.
-abdalrhman mosa
4 years ago
manual of Kodak LS75
hello there, I am a service engineering ,and i need the manual of Kodak LS75 to know how to operation that device. thanks.Reply
  • Features Up to 4K resolution; accepts films up to 14 x 17 in. (35 x 43 cm) and scans 115 lines per second; converts film images to digital images of 1024, 2048, or 4096 pixels x 5000 lines x 12 bits (4096 gray levels); density precision a linear function from; 0.03 to 3.8 OD; self-calibrating and unaffected by ambient light
  • Excellent image quality Density resolution to visualize subtle, low-contrast abnormalities; laser beam discretely illuminates each point (pixel) on the film, with 90%+ transmitted light collected and measured to represent original radiograph; patented logarithmic amplifier to 0.001 optical density.
  • Easy integration TWAIN; Easily integrates into PACS environments whether full PACS users, mobile radiology unit or beginning the transition to digital imaging.
  • Workflow efficiency Easy-to-use “scan wizard tool” walks users through the process to query patient data, acquire, and send images. Complete suite of image-viewing and manipulation functions. Multiformat software features.
Height16 in
Weight90 lbs
Clinical Optical Density Range0.5 to 3.8
Width21 in
Resolution: 4K pixels
Scan rate: 115 lines per second
Illumination system: Type He-Ne laser,Scan: Galvanometer
Collection system: Integrating cylinder
