GE HealthCare - FS50/FS50B
by GE HealthCare
Designed to provide high-end performance in film digitizing, offering superior quality at high throughput.
The steel housing gives the robustness needed for the industrial environment of NDT applications. All standard film formats can be digitized, up to a width of 35 cm (14 in.), without length limitation in any resolution between 50 Μm and 500 Μm. The FS50B is the first and only digitizer on the market that can handle the full density range (D = 0 up to 4.70 D) in one working range with the requested contrast sensitivity. This makes the scanner meet the requirements for class DS film digitizers, according to EN 14096 part 2. This classification has been evaluated and confirmed by BAM, the German Federal Institute for Materials Research and Testing.
-ALPHA1
Fri Apr 22 2016
Installation procedure step by step
189
Dear sir/madam, please how can i get a step by step guide on the installation of the machine i.e. FS50B digitizer? my email is hic2u2000@yahoo.co.uk . Thanks.
203
  • Increased productivity through faster scanning speeds
  • Adjustable scanning speed
  • High levels of accuracy and detection due to high scan resolution
  • Particularly suited for inspection of multi-thickness and composite components
  • Digital image with 12-bit
  • In conjunction with Rhythm software, ideal for on-stream inspection of pipelines in a wide range of industries
  • Utilization of diverse plate types
  • Nondestructive Testing (NDT) dedicated system
  • X-ray control with barcode reader
Height30 in
Diameter21
Weight45 kg
Clinical Optical Density Range0.05 to 4
Width13 in
Laser scan resolution: 50 Μm to 500 Μm in steps of 1 Μm
Scan speed: 14 x 17 inch: 7 sec (Speed mode, 200 Μm);14 x 17 inch: 120 sec (Quality mode, 50 Μm)
