ConMed Linvatec - LS7700
LS7700 HD Compatible Light SourceIntroducing the HD compatible 300-watt Xenon Light Source from ConMed Linvatec. This stand alone, user-friendly light source provides optimal light output so even the most challenging surgical cases are adequately illuminated.
FORUMSView All (5)
1Reply2 months ago | Reset lamp timer How do you reset the timer for the conmed linvatec Ls 7700 lamp, i just changed the lamp for a brand new one but cannot reset the timer so it doesnt workReply |
3Replies5 years ago | Resetting Timer How do I reset the timer for the LS7701?? Reply |
1Reply6 years ago | Conmed LS7700 lamp replacement I use Lightsource LS7700 ,but now it show "replace lamp" I check lamp price is expensive. Please help me for solution this problem Can reset timer on lamp?
Thailand Reply |
- OLED window display with multi-function read out
- HD Camera control connection allows surgeon to safely turn bulb stand-by on/off via the remote camera head button
- HD Camera communication link allows light output to automatically adjust to optimal light intensity when using the IM4000 HD Camera
- Universal light guide receptacle that accommodates both long and short light guide adapters
- Auto bulb-saver feature designed to extend useful life of bulb when light source is not in use
- Easy access bulb replacement
- Locking feature to keep light guide securely in place
- Compatible with the ConMed Integrated Systems’ O.R. Nurse’s Assistant® control system
