Array Corporation - 2905 Laser Film Digitizer
by Array Corporation
Demand the highest image quality for non destructive tests and examination.
Using precise optics and a helium neon laser, the 2905 captures your industrial radiographs    with speed, accuracy and reliability.
The 2905 film digitizer is designed to deliver the highest possible image quality combined with extremely fast scanning. In as little as 7 seconds a 14 X 17 inch film can be digitized at 2k resolution. The 2905 film digitizer can be used with a range of software products to achieve a full integration with your current systems or to provide a powerful stand-alone system.
Using only the finest materials the 2905 is build to last. The 2905 is constructed with an all steel frame an heavy metal closed housing to protect the laser and optics. Coupled with a one-year parts warranty and an outstanding support network, you are assured years of reliable worry free use.
-FTIBOB
Thu Mar 28 2024
Need a quotation for an Array Corporation -205 Laser Film Digitizer
I  need a quotation for an Array Corporation 205 Laser Film Digitizer and I need to know where I can purchase one
Please let me know
Bob Feole
401-640-9579
E-Mail FTIBOB@AOL.COM
-FTIBOB
Thu Mar 07 2024
ArrayFilm Digitizer
Need a quotation and someone to talk to
  • Sensor: Photomultiplier
  • Operating System: Windows 2000, XP, Vista
  • Host Interfaces: USB2I, Twain
  • Smoothing Function: Digital Smoothing with Supersampling
  • Installed Memory: 48MByte Circullar buffer
  • Scanning System: Flat Scanning by Polygon Mirror and Field Flattener Lens
  • Light Source: He Ne Laser, (632.8nm)
  • Scanning Mode: Transmission, B/W
Height330 mm
Diameter764 mm
Power Requirements100-120 VAC
Weight45 kg
Width526 mm
Sampling Pitch: 50 - 500 micron (at 1 micron steps)
Scan speed: 7 seconds at 200 micron
Scanning Length: No limit with specific software
