Burdick - Elite II
The Burdick Elite II ECG / EKG machine provides ECG reports quickly and easily from an affordable; compact package.The Burdick Elite II ECG / EKG machine provides ECG reports quickly and easily from an affordable; compact package. Choose the Burdick Elite II for accurate analysis and simple operation in a portable unit. Perfect for insurance examiners.
FORUMSView All (4)
3Replies6 years ago | MANUAL how to use ekg Reply |
1Reply9 years ago | KIM MEDICAL DIRECTOR I HAVE A BURDICK ELITE EKG. HOW DO I GET IT TO PRINT IN ORDER i,ii,ii,ARL AVL AVF, V1-V6
NEED TO KNOW ASAP Reply |
1Reply10 years ago | Manual for Burdick Elite I don't have a manual for a Burdick Elite. I'm trying to determine how to change the format of the EKG print out to the tradition I, II, III, AVR... print out.
thanks Reply |
[list] [*] Easy, one-touch operation. [*] Portable; weighs just 9 pounds. [*] Battery or AC operation. [*] Stores up to 30 ECGs in solid-state memory. [*] Prints in single-channel or 12 lead format for easy mounting. [*] Simultaneous acquisition and analysis of all 12 leads. [*] Uses the Glasgow Royal Infirmary (GRI) Interpretive Algorithm for documented accuracy. [/list]
Weight | 9 lbs |
Display: 2 x 20 character LCD Keyboard: Numeric entry: hardkey control Input/output: Serial: RS-232 (9-pin D); Signal options: 1 mV input - 1 V output +/_ 1-% Power requirements: AC operation: 115/230 V AC +/- 10%, 50/60 Hz; Battery operation: 12.5 V NiCad rechargeable battery pack. Printout: Printout device: 48 mm thermal dot array; Paper dimensions: 50 mm wide, 45 mm grid, 45.7 m (150 ft) per roll; Paper type: Thermal-sensitive; Chart speeds: 25, 50 mm/sec. +/- 2% Printout formats: 1-channel automatic or manual Acquisition: Lead selection: I, II, III, aVR, aVL, aVF, V1, V2, V3, V4, V5, V6; Modes: Automatic or manual; Frequency response: 0.05 Hz to 30 Hz, -3 db (filtered) Meets or exceeds ANSI/AAMI EC11-1982 standard Input impedance: >50 Mohms; Electrode Offset tolerance: +/- 300 mV; A/D conversion: 12 bit, 5 uV LSB
