Mortara - Eli 100
by Mortara
Interpretive EKG / ECG Machine
Mortara Instrument’s ELI 100 is a portable interpretive electrocardiograph designed to be fast and easy to use. It acquires and prints a 12-lead ECG at the touch of a single key.             The printout, on 108mm wide paper, offers a variety of formats:3 or 4 channel in automatic mode and 3 or 6 channel during rhythm recording.            The ELI 100’s lead fail detection and signal quality check ensure optimal signal acquisition, reducing the need for ECG re-acquisition and thereby lowering operating expenses.            The LCD presents the user friendly interface which prompts the user for commands and displays the unit’s status.            The full alphanumeric keyboard increases staff efficiency by making patient data entry fast and simple.            The optional internal modem provides the means to communicate with the E-Scribe/NT data management system or to transmit to the Federal Aviation Administration.            The ELI 100’s standard 40 ECG internal storage capacity can be expanded to 150 ECGs.
FORUMSView All (5)
-Ray Smith
Thu Jan 17 2019
"Muscle tremor"
My machine has started giving a "Muscle Tremor" error message every time, every patient. It also has ceased working from the battery - when I unplug it, it quits. I'm thinking that the "muscle tremor" may be 60 hz interference from the 110v power supply. Help!Reply
-AimsD
Mon Jun 08 2015
Beeping noise
something is wrong with my machine! It just keeps beeping and is stuck on a screen. It was working fine two days ago and now it isn't. HELP!
-Jaimewrench
Fri Apr 17 2015
MANUAL
Weight11 lbs
