Abbott - CELL-DYN 3700
Hematology analyzer
The CELL-DYN® 3700* is a multi-parameter, automated hematology analyzer designed for in vitro diagnostic use in clinical laboratories. It offers advanced diagnostic capability for medium to high volume clinical laboratories. The instrument performs simultaneous optical and impedance measurements on White Blood Cells to accurately enumerate and differentiate cells as well as provide internal validation of the WBC count. Both Red Blood Cell and Platelet analysis is performed using impedance technology.
FORUMSView All (5)
1Reply5 years ago | Controls and diluentsheath errror I am getting intermittent diluent sheath empty errors. Clearing the fault, refills fluid and background is good. Ran the low control, ok. The normal and high control wbc counts are high. I see blood in lines on the right side around 11,12,13 valves after a sample is run. Is that normal? Any input on high wbc on controls?Reply |
3Replies6 years ago | Service Manual Is there a Service Manual available for the CELL-DYN 3700?Reply |
0Replies7 years ago | Regarding species Can this analyser be useful in case of birds as their rbc's are nucleated Reply |
- Tube retainer with two quick adjust levers
- Data station with flat panel display monitor, keyboard and CPU
- Syringe assembly including WIC/HGB an WIC/HGB diluent syringes
- Sample aspiration peristaltic pump
- Waste chambers
- Automated Sample Loader (3700 SL)
- Closed Sample Aspiration Module (3700 CS)
Height | 27 in |
Length | 31 in |
Weight | 288 lbs |
Width | 30 in |
