LISA Laser USA - RevoLIx Junior
The RevoLix Jr provides a range of surgical solutions aimed at minimally invasive procedures, from ENT to GYN and UrologyThe RevoLix JR is a theatre friendly tabletop 2 micron surgical laser. RevoLix does not cause noise strain to theatre personnel, and the tabletop laser fits into any video tower. A laser trolley is available as an option. Regular theatre utilities are sufficient (standard power outlet 100 240 VAC wide range, no cooling water required). The laser can be transported between theatres and other departments.
[list] [*] Available in 2 models up to 30 watt [*] Range of different size laser fibers [*] Coaxial aiming beam [*] Approved by Intuitive Surgical for use with the da Vinci [*] Can be used in contact and non contact with tissue [*] 2 Models 15 watt and 30 watt [*] Reusable Fibers from 273 micron to 550 micron [*] Fibers are 3 meters long [*] Flexible fibers for use with da Vinci surgical robot [*] Can also be used with rigid hand pieces and flexible scopes [*] Models available for all surgical applications [*] Superior cutting and ablation efficiency [*] Better hemostasis that CO2 laser [*] Cost effective, fibers can be reused multiple times [*] Utilization both in the Operating Room and the Office [/list]
