Stryker - 4700 Adel
by Stryker
Adel Birthing bed
STRYKER 4700 Adel Birthing bed the patented skoocher feature adjusts seat depth from 12.5" to 8.5". The Adel has an IV pole and side rail communications. It also has the adjustable/storable calf supports, with the detachable cushioned calf pads features: Three positions side rails with in-rail motion controls. Four wheel, steel-ring brake system with centrally located activation pedal. Fluid basin, 6" Omni Surface casters with wheel covers. Wood headboard. Under bed night-light. Manual crank bed positioning back up. Self-storing handgrips.
-adavila12
10 years ago
Stryker 4700 not going down all they way
I have a stryker brithing bed that will not go all the way down gets to about 22" off the ground then stops. it should go down to around 19" did the lift calibration and it goes all the way down no problem. I have replaced the lift pot it also had a bad trend motor replaced that as well. the only way this bed will go all the way down is in calibration mode any one else have this issue before. Thank you
-Robb
12 years ago
User manual for Stryker 4700 Adel Birthing Bed
Wondering if anyone has a user manual? Thanks.
SERVICE COMPANIESView All Bed Companies
Height37 in High Position. Low Position- 19
Bed TypeBirthing
Length 90 in
Width37 in
Caster Size: 8" (20.3 cm)    Backrest: 70 degrees    Pelvic Tilt: 3 degrees    Maximum Trendelenburg: 8 degrees    Trendelenburg/Reverse Trendelenburg: 14 degrees    Patient Surface: 33" x 80" (83.8 cm x 203.2 cm)   Head Section Weight: 250 lb (113.4 kg)    Foot Section Weight: 300 lb (136.1 kg)
