Kubota - 2420
by Kubota
Compact Tabletop Centrifuge
Despite the compact footprint as only 350 mm width by 420 mm depth, the 2420 is designed to meet easy-to-use concept. Three channel memory settings make routine work easy and simple. Further more, the 2420 is equipped with brush-less motor so that the user is free from taking care of the carbon brush. Many researchers want to use microplate centrifugation allowing a large number of samples to be centrifuged using less energy and in less time. The 2420 can use the RMP-23 rotor, for centrifugation of 6 x microplate at 1,790xg.
-TechST
Thu Jun 28 2018
C3 errror message afther run
Hi to all. I need know, How can i reset this message "C3"? Thanks in advance.. Reply
-Keith elliott
Sat Aug 02 2014
Re: kubota starts and quits
Kubota T 1400 garden tractor runs a few minutes and quit
OrientationBenchtop
Weight24 kg
Centrifuge TypeMicrocentrifuge
Maximum Speed4000 rpm
