Draeger - Babytherm 8004/8010
by Draeger
infant Warming System
Babytherm delivers an optimal thermo-neutral environment for the neonate, safe from cold or heat stress. Ceramic heater elements and golden reflectors provide even heat distribution over the entire bed area - so the baby will feel comfortably warm wherever placed on the bed. A fully integrated, heated conductive gel mattress keeps the baby warm at all times. You can measure the baby’s central and peripheral (toe) temperature gives you an early warning of thermal instability or possible cold stress, and observe the measured values on the integrated digital display.
FORUMSView All (6)
-Doknow
a year ago
Babytherm 8010 No power up when switching on with main switch, loud beep
solution: main switch defective
-Bishoy
2 years ago
Changing the infared rod
I have a babytherm 8010 it has 300 watt heating elements , but the available is 200 watt , is there any problem if i used these 2 elements?
Equipment: Draeger - Babytherm 8004/8010
-Miguel1212
9 years ago
Babytherm 8004
Error 35
SERVICE COMPANIESView All Infant Incubators & Warmers Companies
  • SmartSWIVEL mechanism allows the family to get close to the baby without compromising warming of the infant
  • The control panel is positioned directly beneath the radiant warmer, so you can easily adjust the settings
  • Can work together with intelligently designed architectural systems, bedside monitoring, and gentle neonatal ventilation
