Gaymar - T Pump TP-400
by Gaymar
Gaymar T / Pump TP-400 Heat Therapy System Heat therapy is effective in the dilation of blood vessels, thereby increasing the blood flow to the heated area. Heat therapy has a variety of uses, the most common being treatment of aches and pains in joints and muscles. The Gaymar T / Pump TP-400 Heat Therapy System provides a means of applying heat therapy by supplying temperature controlled water through a connector hose to a Gaymar T/Pad. The hose is terminated in easy-to-use Clik-Tite connectors.
0RepliesMon Aug 03 2015 | Gaymar test cover Anyone know where I can locate a test cover for a Gaymar T-pump.
Part number TPC-1 Reply |
8RepliesThu Feb 12 2015 | parts I have a KMOD100 hypothermia device made by Baxter. All that's wrong with it is a bad power switch, pn 91357-000. Does anyone know of a supplier who might have this part? (already tried PartsSource to no avail...). Thanks. Reply |
1ReplyFri Jul 12 2013 | service manual
Reply |
