MedRad - Continuum MR
by MedRad
The Continuum MR Infusion System enables you to deliver medication and other fluids to patients during MRI procedures
1ReplyWed Oct 02 2024 | can you program a fluid bolus How do you program a fluid bolus into this pump Equipment: medrad continuum MR compatible IV pump Reply |
3RepliesThu Aug 19 2021 | error code Received error code 23. Anyone know what to do?Reply |
1ReplySat Oct 13 2018 | How to Calibrate the Continuum IV Pump? Hi! I am a veterinarian and would like to use these pumps as a cost effective alternative to the current ones on the market. I have two, but the calibration is out of date and I would love to know if anyone has a protocol for calibrating the output of the pump? Reply |
| Volume to be Infused | 0.1 to 9999 ml |
| Flow Rate Range | 0.1 to 1200 ml/h |
| KVO Rate | 5 ml/h |
| Weight | 1 lbs |
Bayer HealthCare is recalling all MEDRAD(R) Continuum MF Infusion System tubing sets
