Cecil Instruments - Adept 4 HPLC system
by Cecil Instruments
Glycohemoglobin Analyzer
Two Adept CE 4100 dual piston pumps, with flow rates from 0.001 to 10mL/min and a maximum operating pressure of 40MPa, are used with the dynamic mixer CE 4120. The Adept dual wavelength UV-Visible detector CE 4200 is used with an 8µL x 10mm flowcell. A column mounting panel, cover and Rheodyne valve with a 20µL loop are provided. The software provides full system control and data processing using Windows XP or Vista. The system is supplied with solvent and pipe organiser CE 4033 and installation kit 4150 02 00.
