Portable Tourniquet SystemPortable Tourniquet Instrument which includes internal battery power supply, luer lock adapter and hose. LCD display shows tourniquet time and pressure.
- Integrated Tourniquet Cuff Testing-for testing the integrity of the tourniquet cuff with tubing and connectors before or after surgery,as recommended in current AORN standards and recommended practices.
- Rapid Cuff Inflation & Deflation-Inflates a typical 34″ thigh cuff in less than 5 seconds
- Extended Pressure Interlock- A safety interlock limits normal maximum pressure to 475mmHg,and allows staff to select an extended pressure of up to 600 mmHg if required for patients with special needs
- Long Battery Life-Up to 15 hours of operation with tested cuffs
- Connectivity Allows easy integration with OR information networks
- Advanced Leak Detection During Surgery-Monitors the tourniquet cuff,tubing and connectors for air leaks during surgery,and safely alerts staff to hazards or follow-up actions required
- Color Display & Intuitive User Interface-For clearly visible key tourniquet parameters and simplified operator training
- Printer{Optional} Provides a record of events including tourniquet time and pressure levels ,for easy inclusion in patient records
| Height | 9.45 in |
| Length | 1.97 in |
| Weight | 2 lbs |
| Width | 4.47 in |
- Height:180 mm (7.0 inches)
- Width: 120 mm (4.7 inches)
- Depth: 110 mm (4.3 inches)
- Weight: 1.08 kg (38.0 oz)
- Cuff Pressure Range: 50 – 350 mmHg, adjustable in 1 mmHg increments, automatically regulated to within +/- 10 mmHg of the selected pressure
- BFR Pressure Application Timer: 1-30 minutes, adjustable in 1 minute increments
- Reperfusion Timer for BFR: 1-10 minutes, adjustable in 1 minute increments
- Inflation Speed: inflates a typical thigh cuff within 5 seconds
- Integrated Tourniquet Cuff Testing: 30 seconds
