STERIS - AMSCO Reliance Sonic 250
Ultrasonic Cleaner
The Steris Reliance Sonic 250 is an ultrasonic cleaner that uses ultrasonic sound that is transmitted at frequencies generally beyond the range of human hearing. As the sound waves from the transducer radiate through the solution in the tank, the cause alternating high and low pressures in the solution. During the low-pressure stage, millions of microscopic bubbles form and grow in the Steris Reliance Sonic 250. During the high-pressure stage, the bubbles collapse and act like tiny scrub brushes that work in all directions.
FORUMSView All (5)
0Repliesa year ago | OPERATORS MANUAL KINDLY SEND ME AN OPERATORS MANUAL FOR THE ABOVE MACHINE Equipment: RELIANCE SONIS 250 Reply |
0Replies2 years ago | door adjustment adjusting Reply |
0Replies7 years ago | too fast in exhaust Hey guys just curious if anyone had a trouble shooting guide for an Amsco Lab 250. Will alarm for too fast in exhaust typically in a liquid cycle. I do not however have a trouble shooting guide to go through. Thanks for your time..Reply |
- Max Input Power: 185 watts
- Heater/Max. Draw Power Requirement: 284/469
- Amps: 117V - 4.0A; 220V - 2.2A
- Frequency: 42
- 2.5 Gallon solution capacity.
- 42 kHz frequency.
- Removable perforated tray.
- 01 to 96°C temperature settings.
- LED display.
- Tank dimension - Height: 6” (15.24 cm)
- Width: 9.5” (24.13 cm)
- Length: 11.5” (29.21 cm)
- Solution Capacity: 2.5 gallons (9.51 liters)
