Berchtold - Chromophare F 300
by Berchtold
For treatment and examination, the CHROMOPHARE® F 300 provides an allround solution for all emergency room, anaesthetic room and most other investigative clinical environments. [b]Optimal lighting[/b] The F 300 employs highly developed optics, based on the principle of total internal reflection with an integrated Fresnel structure. This optimally directed light provides the user with a large homogenous 16 cm diameter field of light, with an excellent depth of illumination. Absence of shadows, reflections and glare ensure safe working. [b]Ideal colour reproduction[/b] With a colour temperature of 4,500 K, the CHROMOPHARE® F 300 provides ‘natural white‘ light. This is both comfortable to the eye of the surgeon and allows best tissue definition. [b]Efficiency and power consumption[/b] Use of the latest generation 30 watt high perfor- mance LEDs achieves high light output with minimum power requirement. Together with lifetime of at least 30,000 hours the F 300 significantly reduces running costs.
4RepliesTue Jun 25 2024 | F300 lights flashing All 7 LED's flash intermittently when in fact they should be on solid. Turn power off at controls or from wall the lights stop flashing. Approximately 1 day every month the lights will work as normal. Could this be the LED driver or controller.? Any thoughts, as I need to source parts. Thanks. Reply |
6RepliesWed Apr 22 2020 | How to turn off The three outer lights on the Chromophare f300 will not turn off. How can I turn them off?Reply |
1ReplyMon Aug 19 2019 | Dimmer switch Is there a replacement dimmer switch, light not working, and dimmer is flashingReply |
| Bulb Life | 30000 hr |
| Depth of Field | 130 cm |
| Color Temperature | 4500 K |
| Lighthead Diameter | 33 cm |
| Field Diameter | 16 cm |
