Impact Instrumentation - 73X
by Impact Instrumentation
Portable ventilator designed for transport, surge and mass casualty care.
The 73X is the first affordable portable ventilator designed for transport, surge and mass casualty care. This device has audible and visual alarms that allow you to leave your patient alone while tending others. The 73X's simple user interface is easily managed by personnel with limited mechanical ventilation experience. It has an internal compressor and also works with O2. The 73X uses adult and pediatric disposable circuits, and includes a digital airway pressure display, alarms suite, airway pressure limiting, and continuous operation from external power. It runs for 6 continuous hours on the internal compressor and 11 continuous hours on O2. The multi-purpose inlet fitting allows use with or without HEPA or Bio/Chem filters. With no pressure cycling or auto-cycling and no position sensitivity, it won't waste any oxygen.
[list] [*] Compressor: Control, Assist/Control [*] Oxygen: Control, Assist/Control [*] Ventilation Rate: 10 to 20 BPM [*] Tidal Volume: 300 to 1000 ml (rate limited) [*] Airway Pressure Limit Alarm: 15 to 80 cm H20 [*] Alarms: External Power Low/Fail, Low Battery, Low O2, VT Setting, Patient Disconnect, [*] High Airway Pressure, System Failure [*] Power: Internal Battery (rechargeable), External (100 to 240 VAC; 50/60 Hz; 12 VDC) [/list]
