Edwards Lifesciences - EV1000
by Edwards Lifesciences
EV1000 Clinical Platform
The EV1000 clinical platform from Edwards Lifesciences presents the physiologic status of the patient in an entirely new, intuitive and meaningful way. Designed in collaboration with and validated by clinicians, the EV1000 clinical platform offers you scalability and adaptability for both the OR and ICU. The EV1000 clinical platform enables you to choose the parameters needed to monitor your patients and may be used with a variety of Edwards advanced hemodynamic monitoring tools for an integrated Edwards Critical Care System.
FORUMSView All (3)
-Surojit
Fri Apr 15 2022
Do you have Edward Ev1000 engineering mode password
Required Edward ev1000 service manualReply
-Don Cormier
Mon Jan 18 2016
Accuracy Verification
Does anyone out there have a process or procedure to verify the accuracy of the Edwards Lifesciences EV1000 ? Has anyone ever heard of a PX Cal by Merit Medical? It is the recommended simulator used to verify the EV1000 but I can seem to find one? Let me know
Thanks
Don C.
-Vic
Wed Jul 31 2013
EV1000
Fiberoptic cable malfunctioning on flo trac.
I need to know what kind of setup can I use to test this unit?
Does anyone have a Service Manual for Edwards Lifesciences EV1000
[list]          [*] Choice - provides the choice of the parameters you want to view and how you want to view them      [*] Clarity - color-based indicators communicate patient status at a glance, and visual clinical support screens allow for immediate recognition and increased understanding of rapidly changing clinical situations for improved decision making      [*] Clinical Support - presenting the physiologic status of the patient in an entirely new and meaningful way enables you to focus on your patient      [/list]
Height271 mm (monitor)
Length 46 mm (monitor)
Weight2 kg (monitor)
Width280 mm (monitor)
Monitor Display
  • Active display area: 266 mm (10.4 in)
  • Resolution: 1024 × 768 LCD
Data Box
  • Dimensions: 145 mm (H) × 206 mm (W) × 64 mm (L)
  • Weight: 0.9 kg
Pressure Controller
  • Dimensions: 97 mm (H) × 54 mm (W) × 35 mm (L)
  • Weight: 0.35 kg
Pump Unit
  • Dimensions: 280 mm (H) × 195 mm (W) × 165 mm (L)
  • Weight: 3.1 kg
