Siemens - ECAT Exact
by Siemens
The ECAT Exact scanner is the most widely used Siemens PET scanner.
The ECAT Exact scanner is the most widely used Siemens PET scanner. It is a whole-body system providing 2D and 3D volume measurements of metabolic and physiologic processes. The system consists of the ECAT Exact scanner, an integrated workstation, the 3D Advanced Computational System (ACS II), and a patient handling system. It is available as a three-ring system with a 16.2 cm (47 planes) field-of-view.
-Gurhan
Tue Aug 27 2013
Siemens Ecat Exact PET sw problem
On a 2 bed whole body scan, the scan interrupts with an error related to acs.
' Error opening file /home/data/_service_4b8_1b4b_se12.N' which is located on acs.
How can we reinstall sw on the console sw version 7.2.2? Dou you have any procedure to do that?
Thanks,
  • Leading Edge BGO Detector Technology with the highest resolution for accurate diagnosis
  •  Proven Clinical Utility with true 3D acquisition and reconstruction for high efficiency
  •  Retractable self-storing transmission rod sources increase throughput
Axial Field-of-View (AFOV)16.2 cm
